Thanks Herb and RM for the info. I will do some more homework with Yingling and PHT.
Regards Dave |
Pht
Hi Everyone
Just wanted to give everyone a quick update on the progress of purchasing hydraulic hose's for the landing gear on the 337G. I have placed an order with PHT (Refer Herbs post for the web site) and after supplying the relevant P/N to Ashley at PHT he returned a quote of $758 for the 16 hoses. At the same time I have ordered both set's of engine hose's in teflon. Normally you would pay $950 for the 14 hose's from PHT with 6 being firesleeved as standard. In Australia all fluid carrying hose beyond the firewall must be firesleeved, so the cost increased to $1221 I will continue to keep all of you up to date with any cost's related to replacement parts that I feel will be of value. Regards Dave ![]() |
I have had my aircraft for 20 years and had two complete hose replacements, landing gear and engine. I prefer the teflon and went firesleeved this time, as I understand the firesleeve also extends the life by protecting the hose from heat et al.
Despite 20 years of meticulous maintenance, this year they found an oil pressure line up in the passenger compartment over the passenger's knees. I believe it fed wither a pressure gauge or perhaps the hour meter. When they took it out, it all but crumbled. YIKES! Had it let go in flight, it would have sprayed hot oil over the passengers legs. Check that one too. D
David Wartofsky Potomac Airfield 10300 Glen Way Fort Washington, MD 20744 Last edited by n86121 : 12-03-11 at 02:18 PM. Reason: typos |
Hi David
Thanks for the insight, have now asked PHT to supply these hoses as well. Luckily mine are out anyway as I am in the process of cleaning and inspecting all the instruments and wiring etc. Regards Dave ![]() |
| Thread Tools | |
