#29
Kuddos. You have the right answer--the EGT will drop. The "why" does not come from the probe seeing "less gas." The drop is seen whether the probe is upstream or downstream of the crack. The closer to the crack, the greater the change that's seen. The reason is the Boyle's PV = nRT. The gas leaving the cylinder is actually the same temp but the pressure in the exhaust drops due to the escaping gases, so the temp is lower as well ( P and T are on opposite sides of the equation, right? ). As for the CHT change, there is usually no measurable change in the combustion event, so the CHT should not change -- UNLESS the leaking gas is blowing onto the cylinder head metal, then the CHT may be rising a LOT. The good news with a rising CHT is that the escaping gas is hopefully not squirting onto a fuel line! This is really good stuff to know... it can save your bacon. This is only one of the reasons I consider an engine monitor to be mandatory equipment. There are so many ignition issues that can be discovered long before they would cause one to abort a flight from a faulty a run-up.
Walter Atkinson Advanced Pilot Seminars Last edited by Walter Atkinson : 06-28-11 at 10:55 PM. |
| Thread Tools | |
