Unread 04-21-11, 06:55 PM
jchronic jchronic is offline
Larry -
Thanks. I think we may have had this conversation when I inquired before. One responder in the thread you referenced has extinguishers, and the guy with the O2 has a detector system. I'm less interested in an extinguisher than in a detector system, and whether anyone is aware of a system that be can put in a straight 337. I'd assume the O2 system could be adapted (or probably even be a straight drop-in), but are any even available?
Joe
Unread 04-21-11, 11:43 PM
Ernie, I'm curious about the "data of in-flight fires" you mentioned? I haven't heard of any Skymasters with rear engine fires, especially that ended in disaster.
It certainly would be nice to have a fire detector on the rear engine, but I can't image that Cessna didn't consider this. Maybe fire can't be sustained at normal cruise speed because of all the air going thru that rather large air scoop on top of the fuselage. Or maybe air flow is reversed (as it does in so many unpressurized cabins) that you would smell a fire. I guess we need to hear from some one who actually had a rear engine fire...and what they experienced. Don't get me wrong, extra safety equipment is nice to have, but let's not scare the crew.
Unread 04-22-11, 12:26 AM
Returning from the Bahamas in 2007, we had just attended the SOAPA event. Larry and I were flying with Jerry in his G model P337. We were on the first domestic leg from Ft. Pierce to a small airport in Southern Kentucky (can't remember the name now). I was in the rear and I was hearing some kind of knock or something. I had mentioned that I thought I heard something but Larry and Jerry didn't seem to hear it yet. Again, we are at Flt Level 100, we all have headsets on, in one of those noisy Skymasters and it's a pressurized cabin. I am hearing some kind of noise that is coming from the rear or bottom of the plane.
All of a sudden a loud quick knock gets the attention of everyone in the cabin. See I told you I heard something, I thought. Within a few seconds I could smell oil, burnt oil or hot oil. Jerry immediately called center and said that we needed down now. Center told us that Athens, GA was just a few miles on right and told us to squawk 1200 and call Athens. Ok, just drop us then. Anyway, one of the bolts for the rocker arm broke and the rocker made a hole in the cover. You will have to search the SOAPA Bahamas thread to see the photos and story about the amazing repair that day, in Athens, on a Saturday.
You can definitely smell hot stuff in the rear engine from the back seat, right away. We had no fire,
Unread 04-22-11, 12:05 PM
No, there is no data on any fire in the rear-engine compartment of a Skymaster. My research was generally about in-flight fires in GA aircraft, with two noteworthy findings: how little time between first hint and unrecoverable condition (average 7 minutes), and that the more likely location for a fire in older aircraft is in the wiring behind the panel (hence my suggestions on smoke masks and halon extnguishers).
The points made above that air flow in the compartment may preclude fires is interesting and worth pursuing. Maybe there is no cause for my concern about a raging fire while you keep on flying. The fact that Cessna added fire detection on O2s but failed to incorporate it on subsequent 337 models (G and H) may suggest that Cessna did not deem a fire a likely event in non-combat conditions -- after all, the design was done, so adding it would have had little impact on cost or weight.
Unread 04-22-11, 09:01 PM
Guy Paris's Avatar
Smoke masks
Gentlemen, what is the consensus,
what would be the best kind of mask to get?
Guy, the old 72 driver....
Unread 04-24-11, 07:38 AM
Guy -
I purchased four of the PARAT C hoods from Aircraft Spruce at about $150 each. Not cheap and I think there are others at less cost (and less capability). I got them for my whole survey crew, but my feeling is that there should be at least one on board so the pilot can get the plane down.
BTW, my neighbor George Breen, your old airline colleague said to say hello if we ever 'talked' on the web site.
Best regards -
Joe Chronic
Unread 04-24-11, 11:18 AM
Guy Paris's Avatar
PARAT C hoods
Joe,
Small world, say hello to George for me and thanks for the info on the PARAT C hoods.
Were you in at the Falmouth Air park recently? My daughter said there was a Skymaster
in warbird paint there recently.
Keep the blue side up, Guy....
