Thread Tools Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 07-04-10, 08:15 AM
Roger's Avatar
Roger Roger is offline
Strato..
I believe this board exists for and through the civil dialouge of people who both aspire to and actualy own and operate Skymasters .
re: your comment: "Much thanks to this forum, I'm well aware of the costs of ownership. I can afford it".
What I believe some of us are saying is that given your post history it appears that money is of paramount importance in your quest for the "proper" plane. Whether that is because you don't have enough, or are just cheap, it's hard to tell. Skymasters and "cheap or budget" are never discussed in the same sentence, by people who own and operate them
The odds that someone like yourself would come onto the scene and be the one peorson on the planet earth to "beat the system" by finding a Skymaster in the price range that you seem to think is not "so 90's" and fly off into the sunset seems pretty absurd to most users.
Instead what will more than likely happen is one of two things:
1) You will find a cheap Skymaster, and to bring that aircraft to a standard that is safe and effective (i.e. runs when you want it it) the operating finances will consume your budget. or,
2) You will find the same airplane and cut corners on the expenses until it kills you.
So one really has to wonder if there is a level of civility that must be breached to keep someone from either ruining themselves financially, or killing themselves? I for one would vote for the practicallity of telling it like it is, and be dammed if someone was a touch miffed because it tweaked their ego.
Old 07-04-10, 09:36 AM
1973 C337G
2009 - $32,270.33
2008 - $34,665.76
2007 - $24,132.48
Each year was 100 hours +/- 10 hours.
Operating costs are: fuel, insurance, hanger, maintenance. No mortgage on the airplane. The airplane is paid for.
So far 2010 has been a good year. Possibly best ever in terms of cost but the year is only half over and anything expensive can break at anytime so we'll see.
Hope this helps.
Ed
Old 07-05-10, 07:00 AM
jchronic jchronic is offline
That's good info, Ed; thanks. Can you share what caused the spikes in any unplanned maintenance?
Capt Ahab
Old 07-05-10, 02:34 PM
These numbers come from my spread sheet off my computer. The spread sheet simply totals the categories for each month and I can read the totals in any category for the month or year. The "airplane" category had these numbers I posted for the past three years. My data prior to that included operating multiple airplanes under the one "airplane" category so 2006 and earlier was more than just the Skymaster so I do not have easy access to the totals for just the Skymaster prior to 2007. Since 2007, I have been operating only the Skymaster.
As for what causes the variations in operating costs from year to year is simply that some things cost more to fix or replace then others. I could go back to my files and dig out invoices to see exactly what went where but that will take too long. What I can do is recall from memory some examples of things that have either been fixed or replaced over the years since 2002 and the approximate cost for these things to hopefully give you an idea of what can all be involved financially.
Each year the "base price" annual runs about $4500 gradually increasing from year to year. That is to say if my shop takes the plane apart and puts it back together and finds no discrepancies then the annual will be $4500. Anybody who has operated an airplane knows that this never happens. Something is always broken or should be replaced simply from a preventative standpoint. If I have an annual that does not turn up any major discrepancies then I will take advantage of that and spend money on something that should probably be replaced but did not necessarily have to be replaced. I mentioned in my last post that 2010 so far has been going well. If the annual in this coming November 2010 proves to be a relatively discrepancy free annual then next on my list are all new flight control cables.
In the past several years items that have been repaired or replaced and approximate cost including labor are as follows in no particular order:
1) flap cables - $2000 to $3000
2) props resealed twice and other prop parts (2002 and again in 2009) - $1500 to $2500/prop
3) both vacuum pumps - $500/pump
4) new prop governors - $2700/governor
5) rear muffler twice - 2003 and again in 2007 - $2000 to $2500 each occurance
6) motor mounts on both engines - cannot recall price
7) starters on both engines (internal gears failed) - $3500/engine
8) throttle, prop, mixture cables on both engines - cannot recall price
9) windshield - $2500
10) several interior plastic furnishings and interior parts - $4500
11) much autopilot repair and avionics repair over the years - several thousands
12) new encoder - $500
13) replaced signal conditioner and fuel gage issues - $2000
14) new brake discs will be installed this fall 2010 - not sure yet
15) rear prop removed and repaired due to F.O.D. - 2007 - $1500
16) replaced all hydraulic lines for the landing gear - cannot recall but expensive
17) several electrical issues, rewiring, battery cables, etc. (see my post on "over-voltage") - $2000
18) new auto-pilot attitude gyro - $2000
19) over-haul second attitude gyro - $500
20) replaced ELT with used serviceable unit - $150
21) many hrs & parts to get both the original Cessna CHT/EGT system and JPI CHT and EGT systems working - $$$
22) fuel leaks, lines, and senders repaired or replaced - $2000
23) aircraft trim system was completely out of rig and need to be redone - cannot recall
24) electric trim inop and rebuilt to function proprerly - $1500
25) replaced rear cowl-flap motor (front one getting slow but still working) - $2000
26) repaired cracks two or three times and repainted rear cowl (it took awhile for the shop to get it right) - $$$
27) repaired a fairly large crack in the belly skin behind front left exhaust pipe
28) replaced fuel caps
29) had enough yet?
Anyway, hopefully readers get the idea. As I have said before, the C337 is a wonderful flying machine. They are expensive as any twin engine airplane would be. People who are considering operating these airplanes need to understand that the costs are expensive and can vary widely. No two Skymasters are the same. Turbo and P-models will only add to the costs, ALOT. If you can live with the costs, I would recommend the airplane in a heart beat.
A $15,000 annual is routine for me. A $20,000 annual is not out of the question and I probably would not start to cry until the annual exceeded $25,000. My smallest annual was about $8500 and the highest was $20,000. The big one was the first one in 2002. Last year was around $15,000.
Just remember, the easy part is the purchase. The operating costs in short order will blow through the acquisition costs.
Hope this helps! This is simply my experience. Others may be different. I enjoy my airplane and am mostly happy to have it.
Ed
Ed
Old 07-06-10, 07:15 AM
Edamus -- good post
Thanks for sharing your actual experience. Mine is similar but not quite as costly. My approach to the airplane is identical, however, ie recognize it will be expensive, be happy when an annual doesn't go completely bad and use those times to continue to pour in funds to maintain some questionable and/or wearing items. These are old airplanes, and to keep them safe and properly maintained is going to take money. I recall some posts on this site of guys getting away with $1500 annuals...I thought it was just me, but I don't find this realistic at all. I have some historical bills for my bird from prior owners and from what I can see, the worst was a $25K annual. My worst was $14K and last year was the best at $4.2K. This is just annual, doesn't include hangar, insurance, fuel etc etc.
Old 07-06-10, 08:24 AM
Very Good, Ed
I no longer own it, but I bought my Skymaster for a good price, in 2001, and immediately spent 25K on a new engine and installation. My worse annual was about 12k. Not counting the 2K for a new rear cowl flap motor, and new torque tubes for the flap controls.
After about 4 years of ownership, I spent another 30K to buy a new rear engine. And more money to get it installed, along with a new engine mount, new lord mounts, and a new exhaust.
My situation was a little different, in that I could, for several years, do owner assisted annuals. While it took quite a bit of my time, I was able to save some money by opening up and assisting on closing up the airplane. I recall one of the maintenance shops saying that Cessna had a block time of 39 (or 41) hours for the annual inspection. Just the inspection. Removing panels, inspecting, and closing it back up.
For the last few years, I kept the plane at my hangar, next to my house.
Old 07-06-10, 04:46 PM
Cole5Oh5's Avatar
Cole5Oh5 Cole5Oh5 is offline
Cole5Oh5 is on a distinguished road
There You Go
There you go Stratobee.
Real world numbers from people who own Skymasters. Depending on location, you can count on higher or lower numbers for you annual. You'll still have the whole insurance thing to contend with, along with hangar or tie down, and then there's ongoing maintenance, and gas.
If you still plan on having it go across the Atlantic, add a whole bunch more for the ferry flight. Last months EAA magazine had a good article on it.
Well and Often
http://www.youtube.com/watch?v=iU2dc-If4-0
