Thread Tools Rating: Thread Rating: 852 votes, 4.95 average. Display Modes
Unread 12-12-09, 11:10 AM
Not True
Part 43 of the Regs allows alternatives to the OEM Service Manual. Part D of 43 is allowed to use for 100 hour inspections / Annuals.
Your SOAPA SID Steering committee has researched this and this is still working with Cessna on some clarification of these concerns.
Ultimately the inspection has to be signed off by the IA and it is up to his discretion based on Part 43 of the regs. If the IA need clarification on this then the local FISDO is involved. The FAA rep from the FISDO can require all or any inspections based on their interpretation of the OEM SM and the regs in Part 43.
That's my understanding and maybe their are others out there that can chime in.
Look Below at Section 43.5 (C)
§ 43.5 Approval for return to service after maintenance, preventive maintenance, rebuilding, or alteration.
top
No person may approve for return to service any aircraft, airframe, aircraft engine, propeller, or appliance, that has undergone maintenance, preventive maintenance, rebuilding, or alteration unless—
(a) The maintenance record entry required by §43.9 or §43.11, as appropriate, has been made;
(b) The repair or alteration form authorized by or furnished by the Administrator has been executed in a manner prescribed by the Administrator; and
(c) If a repair or an alteration results in any change in the aircraft operating limitations or flight data contained in the approved aircraft flight manual, those operating limitations or flight data are appropriately revised and set forth as prescribed in §91.9 of this chapter.
[Doc. No. 1993, 29 FR 5451, Apr. 23, 1964, as amended by Amdt. 43–23, 47 FR 41084, Sept. 16, 1982; Amdt. 43–31, 54 FR 34330, Aug. 18, 1989]
