View Poll Results: Do you have airframe wing modifications (tip tanks, etc)
Yes 10 28.57%
No 25 71.43%
Voters: 35. You may not vote on this poll
Unread 08-23-09, 08:48 AM
it's a good point.
I read, someplace, when I was researching the SID's that had already been developed, that mod's to the wing may involve additional inspections. Alternately it may involve further certification from the developer. In the case of the O-2, we certainly aren't going to get further certifications. Nor will there be any from Robertson, who's STOL kit involves quite a bit of modification to the wing.
It's why, after I sent out the survey, that I thought we better ask about wing mods.
Unread 08-23-09, 11:20 AM
tropical tropical is offline
I think as part of your survey as well as any comments to Cessna about this program should separate the O-2's from the civilian 337's. Lumping them together will only add inspections to 337's that simply aren't needed.
As in the 400 series Cessna there is a huge difference between an airframe that's been in high use/high cycle commercial operations versus a private owner/operator.
Unread 08-23-09, 09:18 PM
The model number for an 0-2 starts with M, while for a civilian model it does not. That separates the 0-2's from the rest.
Unread 08-24-09, 01:34 AM
You better be sure they are being separated. It was the O-2 that cause the wing spar inspection AD but yet they included the civilian models also.
Unread 08-24-09, 06:31 AM
There were also civillian 337's used in low altitude survey, ie, fish spotting, powerline/pipeline patrol, at the time, so the same stresses, and gust loads, were put on those airplane too.
Unread 08-24-09, 11:28 AM
Yes, and that's why one of the polls specifically addresses this point.
Unread 08-28-09, 09:07 AM
Dale Campbell's Avatar
Wing Load Changes
My bird came from Europe with two previous owners. I know they were IFR rated and used it for business a lot. Probably rough weather flying. Always hangered and they put a total of 2400 hours on before I put an additional 400 hours on it. There are no changes to original wings. It does have De-Icing Boots. All interior of wing was zinc chromated as was interior of cabin and booms. That should have cut down on corrosion. My bird has 150 gallon tanks, so that is 900 Lbs. of fuel pulling down on wings. That is a lot more weight than the earlier birds. Dale Campbell
