Unread 06-10-09, 11:48 AM
nick nick is offline
nick is an unknown quantity at this point
cargo pod
need to get installation instruction from cessna TECH SUPPORT. cost is $104. I can send you a copy for $50. It is only four pages.
Unread 06-11-09, 01:13 AM
Ok, sounds like a plan. Where to send the check?
Unread 06-11-09, 01:35 PM
cargo pod inst.
Rob,
please send an email to me with your information and I will forward you mine.
thanks nick
Unread 06-29-09, 12:09 AM
Nick, did you mount antennas on the pod, or just left them on the belly? The instructions don't really address the antenna issue.
Unread 06-29-09, 11:55 PM
cargo pod
I first took the antenna off, and fabricated a replacement plate. Later, I decided to install the antenna back in the pod, but I think it should be left out because it can easily be damaged by any luggage in the pod. I was selling the airplane and I did not want to remove the ADF. Otherwise, I would have pulled the whole ADF unit out.
