Unread 06-07-09, 10:28 PM
I put the new mounts in the front engine today. Right now three of the four mounts line up with the bolts. The two rear mounts and right front are aligned, but the left front mount is not aligned. Has anyone ever had this problem? I haven't tightened the rear mounts yet, but if I do will this make the front mount line up better? Any suggestions?
Unread 06-08-09, 01:04 AM
It can be a little tricky but you just have to lift the engine a little and jockey it slightly to get everything to line up. You may need to take out one of the other bolts to get the other started. Do you have two people? Take a small drift punch to line up the hole closer works too.
