Unread 04-29-09, 09:00 AM
Dale Campbell's Avatar
Avionics
Hi Guys,
I was taught to always start the rear engine first then the front engine and last turn on avionics. When shutting down, first turn off avionics then front engine and last the rear engine. That is what I always do. The front engine is shut down as I leave runway at small fields but at larger airports as I arive at ramp. Dale Campbell
Unread 04-29-09, 10:11 AM
My starting procedure, which I believe is based on the POH, is the reverse: front engine first. The reason for this is important, and I think this procedure has saved the day several times. The cable run from battery to starter is much shorter, probably 3 to 5 times shorter, for the front engine, so the electrical resistance and voltage drop is much lower. There have been a number of times when, after not using the aircraft for several weeks, the voltage at the front-engine starter was so low that it barely turned the engine, and it was just enough to get the engine started. At times cranking would stop after a couple of engine turns, when battery voltage dropped too low, and it was lucky that after letting it rest for a few minutes, the engine caught on the first turn of what was obviously a dying battery. In most of those instances, I believe the rear engine would not have started, and switching to the front one would not have worked because the attempts at starting the rear engine would have dropped the voltage even further.
I hope others will jump in and comment.
Unread 04-29-09, 01:14 PM
Engine starting
Hi Ernie,
You are correct, the manual states front first. Again the airport I fly from is dirty so I am very sensitive to puting debrie into rear prop. I also have a battery charger/maintainance devise that is always plugged into my battery, so low battery from sitting is no longer a problem. I have had stones, screws, sticks and even a chunk of aluminum cowling hit the rear prop. The upper rear 1/2 ring cowling front of prop is in shop as we speak getting replaced with new carbon fiber because it cracked off and hit the prop. So thats why I start rear first and then the front. My rear engine always start easier then the front for some reason. That is another reason for my starting proceedure. Dale
Unread 04-29-09, 06:20 PM
I start the rear first on the O-2 because my battery is just inside the baggage door, plus, you can clear the rear engine verbally without the front one running. Yell out "Clear Rear", verify no one present and crank. I can visually clear the front prop.
With the front engine running, you cannot verbally clear the rear over the noise.
Unread 04-30-09, 08:39 PM
JeffAxel JeffAxel is offline
this is interesting. My POH doesn't specify which engine to start first, but makes the point of the shorter cable run to the front engine, while also pointing out that if you start the rear engine first, you can hear it and let off the starter sooner. If my battery was so low as to barely start the plane, and I was launching into IFR conditions, I might choose to charge the battery on a battery charger first just to be sure the battery was well enough charged to keep the battery contactor open when a heavy load was placed on the electrical system, like raising the gear. Just a thought. There is a supplement in my POH about vacuum pumps, saying to check the vacuum manifold on start up and shut down on each engine, and to shut down the engine you started first, first;to be sure the other vacuum pump is working, and the manifold is working as well.
