Unread 03-30-09, 12:27 AM
I beg to differ with Ed, but I have exactly the same aircraft and you can indeed use a calibrated dipstick as long as you recognize the limitation, specifically that it won't measure below 30 gal per side. Above that, it's very accurate. Most of my flights are over water, adequate fuel is more critical to me than for most other Skymaster pilots, and I spent considerable time researching the system and making the information available in the Fuel Supply Management page at www.SKymasterUS.com
Other techniques, like supervising fueling and keeping close tabs on time, are critical, but for me the most important is climbing on the wings and using my dip tube.
Unread 03-30-09, 08:20 AM
Ernie is correct. I was thinking in terms of the entire wing. One other thing I would like to add for Dave is to make certain you understand YOUR fuel system on YOUR particular model of Skymaster. These fuel systems vary greatly depending on the model!
Thanks for keeping me on my toes Ernie. I appreciate attention to detail!
Ed
Unread 03-30-09, 12:31 PM
Dear Ernie,
Just so I fully understand (given the model year differences) my 73 P337 with 128 gal capacity, should be the same as your 73 in fuel tankage. That is, if I can see fuel below the fuel tube, then I have at least 30 gallons. I will of course confirm this myself, but correct me if I am wrong.
Dave Dillehay
Unread 03-30-09, 01:26 PM
Yes, if the wing/tank arrangements are the same between your P model and my normally aspirated model, then if you see a thin film of fuel under the filler hole you have 30 gallons, and the tube (after you calibrate it) is used to determine quantity when you have more than just a film (1/4", 3/4", 1.5", etc.). The airplane must be on a level surface for accuracy, and, as mentioned by others, you need to wait until fuel has settled because the fuel SLOWLY feeds down to the inboard part of the tank system.
Filling is important, also. If you're starting from a very low fuel situation, use of the visual-and-tube technique on the first tank/side you fill will give you an inaccurately high reading, because the weight of the fuel on that side (unbalanced by the emptiness of the other side) will make the aircraft tilt in the direction of the tank you are filling, bringing more fuel under the fill port than there would be if the aircraft was level. So, when you just barely see fuel under the port (after waiting for fuel to settle, of course) you won't have 30 gallons, but 28 or 26 or perhaps less. Same with the tube. After calibration, if it shows you have 50 gal, you might have 45. The solution is to go fill the tank on the other wing and then return to the first tank to re-measure and refill as necessary. Generally, this iteration is not needed on the second tank/side, just the first.
Unread 03-30-09, 06:57 PM
Thumbs up
shadden, shadden digflo !!! unbelievably accurate all it takes is for the dumbass to reset the computer every time you get gas. on long fligths i would switch to mph. best mpg was 9+ gallons per mile
Unread 03-30-09, 11:32 PM
rhurt's Avatar
rhurt rhurt is offline
Agree, but.
You might want to lean it a little. (just kidding)
Regaardless the flowmeter, Ernie has a great point about fueling. An impatient line guy with a fast nozzle can leave you five gallons short per side.
Unread 03-31-09, 02:06 AM
dwbomber dwbomber is offline
dwbomber is an unknown quantity at this point
Smile Fuel Management
Hi Dave...congrats on the P337 purchase. Because of a past situation , I will never let a line guy fuel my airplane. I take my time and fuel slowly to the brim. Just remember, many a fine pilot have run a skymaster out of fuel. I have a shadden, and I love it, but time is always been my overriding factor. With 5 1/2 hours of fuel, I never push any legs past the 3 to 3 1/2 hour mark. Yes, when you are fat, dumb, and happy up in the upper teens in your pressurized beast (god, I love skymasters), it will be hard to let her back down. JIM
Unread 03-31-09, 01:04 PM
if you look at the gas pump meter you know how much was put in, so if the line guy is impatient you will know
Unread 04-29-10, 09:50 PM
tkirklindale's Avatar
tkirklindale tkirklindale is offline
tkirklindale is on a distinguished road
engine gages
is there any stc engine gages out there for the 337 ??
