Unread 03-25-09, 05:31 PM
Roger's Avatar
Roger Roger is offline
I too have had reoccuring problems with my left fuel guage, and noticed something a few weeks ago when working on a fuel leak caused by a dried cork . If I played with the wires that go between the outboard sensor, and the inboard, it caused the fuel guage to spike, and at times work. This even if I isolated (taped down) the connections that went through the tank caps.
I now beleive that I may have a crack in the wire itself. Why else when I move them around while isolating the connections, should I get what amounts to different impendence or continuity .
Unread 03-25-09, 06:00 PM
Roger
You have the resistor type system on your T337D, now this system requires quite a bit of maintenance, the grounding of the tank unit has to be 'spot on' if you have any corrosion under the tank units or the ground strap is not clean this system will not work correctly.
On the resistor type system a open circuit from the gauge to the the tank unit will cause full scale deflection of of the fuel gauge, and a short would cause the opposite effect.
Easy check for volts at the tank unit, also check that the tank unit is grounded and no corrosion on any of the connections.
Regards
Pete
Unread 03-27-09, 01:39 PM
Update: I spoke with Aero-Mach a few hours ago and they are sending my signal conditioner back and they feel they have it working per spec under all conditions now. They found several things wrong and feel they have the unit repaired. I should have it by Monday so I will keep you all posted as to the results. They did say however if I still have problems, they would not attempt another repair but would only sell me an overhauled unit. Aero-Mach did not charge me any additional amount for the second round of repairs so kudos to them. I hope it works when we get it all back together. Stay tuned!
Unread 03-31-09, 05:54 PM
The signal conditioner arrived today and I promptly went out to the hanger to hook it up. It PROMPTLY failed. My IA got the same intermittent behavior on the gauges by wiggling the 9 pin plug that is attached to the signal conditioner. Aero-Mach is sending an overhauled unit tomorrow to see if I get the same behavior with that one. This is fun.
Unread 03-31-09, 07:17 PM
I was kind of unhappy when I gave up on the system and now rely on fueling supervision, visual confirmation and time. After hearing what you're going through -- no longer unhappy.
Unread 03-31-09, 08:45 PM
hahahahaha.....Thanks Ernie, that was funny!
Unread 04-06-09, 05:38 PM
I received the over-hauled signal conditioner on Friday and plugged it in today (Monday). It has the same erratic behavior as my original one.
