Unread 03-05-09, 07:21 PM
In through the out door
I thought of the critter idea, but then couldn't figure why if they found the rear door locked (ie screens in place) why they wouldn't just so to the side door (cowl flaps) or the front engine (no screens unless plugged with a cowl plug I guess). I wondered if they might also be there in case something came loose in the rear engine bay, then with the screens it wouldn't be able make its way to the rear prop causing a greater catastrophe.
Sounds like removal and log entry is the way to go. Thanks.
