Go Back   Skymaster Forum > Mechanics and Service Providers
Unread 02-09-09, 04:45 PM
Todd Gessel's Avatar
I want to thank everyone for the help. The mechanic worked on it some more and found that the hydraulic hoses were routed in a way that caused the problem. A slight adjustment to the location of the hose routing seems to have corrected the problem.
Unread 04-07-09, 11:50 AM
The routing of the hoses is the problem. You want the hoses positioned so down locks are held in the up position until the gear strikes them and causes them to start to swing. At that time the movement opens a valve and causes them to pressurize and lock down.
If the locks start to pressurize too early you will have problems.
Good luck.
