| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Janitrol heater
Two questions on this thread:
1) Has anyone taken advantage of the C&D special show pricing and put in their heater replacement. If so, what was the cost of the heater, and what was teh cost of the labor to swap it out. pirep on it? 2) IO've looked throughout my POH and can not seem to find the fuel flow requirement for the Janitrol heater on my T337C. I understand my new JPI fuel flow gauiges will not reflect the fuel used by the heater and I want to makie sure I'm calculating actual burn with the heater turned on...anyone have the fuel flow numbers? -Robert Morris rmorris@agsi.us ________ Sc2 replays Last edited by rmorris : 03-12-11 at 11:59 AM. |
C&D heater
As I recall it was about $3k. I haven't nailed down the install cost yet, as it was part of a lot of other work, but will advise when I've got a number.
In my turbo 1969 T337D it was a bit tighter then expected, and required some mod of the cross-over bracket holding the combustion fan. I wondered why my mech didn't just use the combustion fan mounted to the heater, and will ask that question. I'd also asked the shop that put it in to check the fuel pressure, which I believe they forgot to do, so the heater works, but fails to roast in cruise. I suspect the fuel pressure regulator and/or fuel pump from 1969 may be a bit tired. Will update as it gets finished off.
David Wartofsky Potomac Airfield 10300 Glen Way Fort Washington, MD 20744 |
1 Gph
I also recall that the pilot should assume 1 GPH being used from the front engine tanks for heating.
| Thread Tools | |
| Display Modes | Rate This Thread |
