Placement of Aspen on panel
Hi All,
Had the Aspen Pro istalled about two months ago. Fabulous piece of equipment. Everything worked as advertised right from the first flight. Best aviation invention since the wing! I made one error. Notice in the mock-up panel in the photo submitted by Jakes Dekkers, that the Aspen is offset about 1.5" to the left of the control wheel shaft. This is because the Aspen fits into the hole left by removal of the attitude indicator, and on my ship and, apparently, Mr. Dekkers', the AI is not centered. over the shaft. Once the Aspen is installed, it's such a Christmas tree, with all the glowing colors and wealth of information beautifully and compactly displayed, the off-center position of the unit seems really assymetrical and weird. I had an aluminum panel overlay made up and could have changed the layout slightly to achieve symmetry, had I noticed the problem beforehand. If you're going to spend the money, you want a nice-appearing panel, not one that's lop-sided. I plan to have mine redone at some point in the future. Got rid of the super-junky, brittle and cracked plastic Cessna overlay in the process. Next dream project: getting rid of the rectangular 1948 Studebaker engine instrument and fuel gauge cluster. Worst thing in the airplane in appearance and function. GJ Humphrey Concord, NH N3CU, 1973 T337G, SN P3370063 |
Gordon
How about a photo. I am curious about the placement and the view.
It's weird, but in the "old" steam gauge configuration everything was also 1,5" off to the left - I did not even notice it then.
To the Blue Room!! Jakes Dekker |
Time sure goes by verrryyyy slooooowwww when your plane is in the shop. I do get pictures from the shop on a semi-regular basis, showing the progress that's been made. The aluminum left panel has been cut and the new radio rack has been installed. Now the panel has to go to the shop that will be powder coating it (grey). In the meanwhile a new breaker panel was also cut to house the new avionics breakers, and this panel will go to a shop in the States that makes electroluminescent panels, so one can actually read the different breakers' assignments.
Tic toc tic toc...
And in case anyone is wondering, I'm still waiting for GKEY to be finished. Good thing the winter up here in Cold Lake (no pun intended) is so bitterly cold (- 31 C) that nothing can survive outside, so no flying would have been possible anyways.
The avionics shop is waiting for the powder coated instrument panel to return, and then the assembly of the panel can begin. The harnasses are all in, new radio racks fitted and the new windscreen is ready for installation. They did find one last problem though (that once known about, if left un-corrected would have invalidated the airworthiness): a previous person working on the plane had disconnected the wires to the windscreen defrost unit the way Cessna intended it to work, and hardwired it directly to the battery and the switch. This is dangerous, since the defroster can work while the plane is not moving, and has no airflow over the windscreen, thereby damaging or even cracking or melting the windscreen. The factory-fitted way dictates that the defroster cannot work when (a) the wheels are down, and (b) the front engine is not running (aka my shop). So they changed the wiring back to the way it was supposed to be. Airwothyness saved.
The (expensive) upgrade is almost done, and yet the Gremlins keep coming out from somewhere...
Newest Gremlin: My windscreen hotplate has decided to finally part with this world. It has been fixed twice before, but this time it could not be revived. Where I fly a hotplate is needed about 6 months of the year. Anybody wants to sell a hotplate?
OK, we're almost done now. GKEY is still enjoying her stay "at the spa", but things are coming to a close for this phase of the upgrades.
Besides the 2" ASI and ALT intruments that are still coming, the rest is in the panel and ready to play. They did a power up test again, this time with everything installed (previous time was on the bench). I got some pics, and boy! Wow. I'm in awe. From the pics I can see that the Garmin 530W and Aspen Pro and all the other fancy stuff are communicating with each other just fine. This morning they have completed configuration of the Garmin 530W, the GTX 330 and Aspen's colorbands on the ASI. Due to a newly known glitch on the software ver.3.2 on the 530W, I have opted to stay with the previous software version until Garmin issues a fix for their new problem. This week they are taking her out of the hangar to do the compass swing with the wet compass and the Aspen. Then they will put back the cosmetic trimmings, and voila! I asked for a physical weight assessment since so many things have changed, and that will be done when they do the new W&B.
| Thread Tools | |
