Old 09-09-08, 04:01 PM
Diamond Service Diamond Service is offline
Diamond Service is an unknown quantity at this point
Counter drum altimeter
Thank you for your answer.
The reason I ask is that counter drum altimeters are required for commercial operation in Europe.
Rgds Troels Hansen
Old 09-09-08, 09:04 PM
JeffAxel JeffAxel is offline
Troels,
the altimeter is an ARC EA-401A, it was a factory option on Skymasters. The full part number is 42540-3128. It is a servoed electric altimeter/encoder. The altimeter part works just fine, the encoder part can be troublesome, and expensive to fix. They are pretty common encoding altimeters and it shouldn't be too hard to find one and no problem to install since it could be ordered that way from the factory. If you use one of these altimeters, you have to have a non-electric altimeter as a backup in case of an electrical failure, probably just keeping the altimeter you already have as the #2. I have a repairable core if you are desperate, but it will be expensive to fix I would guess.
Old 09-10-08, 09:28 AM
That makes sense, as we had a non-electric altimeter also in the airplane.
Old 09-11-08, 05:32 PM
IFLY4YALL IFLY4YALL is offline
IFLY4YALL is on a distinguished road
Originally Posted by larry bowdish View Post
1969 C337D Skymaster for sale, $40,100
6 Seats, Cessna cargo pod, RDR-160 Radar, in pod, De-Ice boots in good condition. Aero Enhancements overlay with blue lighting around instruments, light strips below glare shield and lower instrument panel. FE 490 SFREMAN, RE 220 SFREMAN, 220 since spar inspection, 8240TT.
Dual KX-170 nav comm, Terra ADF, KN62 DME (switchable), slaved HSI, Terra transponder, King transponder, STS loran, AVMAP portable GPS mounted to yoke. 6 place factory oxygen (tanks needs to be certified). Currently undergoing annual.
Hey Larry,
Is the old girl still for sale. I am interested.
Mark Fitzgerald
Old 09-11-08, 05:37 PM
Larry,
Sorry, I didnt see the post announcing that it was sold.
Mark
Old 09-11-08, 06:59 PM
You should look at Paul and Mary's airplane. It is nicely equipped.
Old 09-12-08, 06:10 PM
I have an electric Altimeter in the TwinCo. It was in it when we bought it and seems very accurate. Not sure if it has the encoder or the static unit next to it. The static unit has to be there for legality reasons as Jeff indicated. Seems like I have seen these in Trade a Planes from like Airwich in Kansas. Might be a good place to look.
Old 09-12-08, 08:31 PM
The cool thing about them, as opposed to the ones you more typically see, is that you can dial in 29.97, as opposed to saying, 'should be about there'
