Unread 12-16-07, 04:28 PM
Frank Benvin's Avatar
I took a 110 volt gear motor and put a pully on it. Then I took a boat winch and extended the shaft and put a pully on it and made a tension arm with pully to connected the two. I can use the gear motor or if the power goes out I can mannully winch the plane in
