Old 03-06-07, 03:43 AM
You can adjust the switch by undoing the 2 screws and sliding it in/out. But make sure you do at least 3-4 retractions after adjusting just to make sure that the switch works correctly and that the gear is in the down lock.
If the spring levers have been bent and you have striaghten them, i would see about changing them as it will be a weak point.
Cheers
Pete
