A P337 is not certified about 20,000, so it is not "legal" to fly it up there.
Depending on outside air temperature and power setting, the P337 will frequently not maintain full cabin pressurization very much above 20,000. The rear turbocharger on this aircraft is the controlling factor. According to the best information I have, the P337 will fly above 20,000 if you running a high power setting, and does fine up there. Above 25,000 is probably not practical. To answer the next question that frequently comes up, no, there is no way to "turn off" the pressurization and use the turbo output just for the engines. The T337 turbochargers are not the same units as the P337 (and it's not the same airframe, a different airplane really). The T337 turbochargers serve only the engines, and in that airplane, you can get a higher service ceiling assuming you have the right oxygen equipment (pressure demand mask above 25,000' if I recall correctly). Remember that 31,000 on the turbo is a true service ceiling - rate of climb less that either 50 or 100 fpm, I can't remember, and you are probably getting 55% power or something like that. The actual operating ceiling that one might really use is lower, perhaps in the mid to high twenties. Kevin |
Thanks. Ken MacLean |
Ken,
The FL200 limit is an operating limitation, so it is not approved or legal to fly higher. The cabin altitude in a P337 is 10,000ft at FL200. I am not sure why they limited the P337 this way. The P210N has the same pressurization setup, but can fly to FL230 where the cabin altitude is 12,100ft or so. The R model P210 is approved to FL250, but you must wear oxygen above FL230. It also shares the same 3.35psi pressurization setup. |
Thanks for the info. I presently have 3 airplanes for 3 different missions and a P337 would replace all 3 if it could legally go to FL250. That would save a lot in insurance, hangaring, maintenance, etc. (I already know about 337 maintenance with my T337C.)
Is FL200 in the limitations section of the POH? Also, I haven't seen anywhere an FAA definition of "certified ceiling". Where is that found? Thanks. Ken |
Ken, the limitation is in the Limitations Section of the POH.
I've seen 210 with no problem.
| Thread Tools | |
