Unread 06-02-02, 01:00 PM
N69S
re temp sensor
Paul
The guages have a voltage regulator as a source of stable reference. I have a feeling the voltage regulator may be at fault, however, both front and rear should drop if this occurs.
The sensor itself is a thermistor or a resistor that varies with temperature. There is a possibility they could jump based on an internal fault. This can be caused by a temperature shift.
Think I would swap the sending units or the wires to the guages and try again.
fyi
