Unread 01-29-23, 12:20 PM
The Continental M-0 repair manual has all the info on procedure and sealants to use, on the road and from memory…
Clean bore well with MEK, there is a spray primer that is applied, then the purple case half sealant goes on the bore, then the permatex brown liquid on the seal and install.
When I can I will get the actual numbers of the items.
