Unread 05-01-22, 10:16 AM
SteveG's Avatar
SteveG SteveG is offline
alternate solution
An impact screw driver will also likely solve the problem. Their advantage is that they simultaneously seat the bit into the screw head and apply a torque to the screw. One only needs to break the fastener loose with a couple of degrees of rotation, then leaning on a manual or motorized driver will turn the screw out without the bit walking up out of the head. And they are a lot less expensive than a rivet gun plus torque tool if you don't already have the gun in your tool box.
https://www.harborfreight.com/impact...ase-37530.html
https://www.mcmaster.com/impact-scre...crewdrivers-5/
