Unread 12-24-17, 12:25 AM
JeffAxel JeffAxel is offline
Dennis, my experience with deiced Skymasters in icing is they don't do very well. They don't climb all that well clean, and the rate of climb really falls off with any ice accumulation. They also loose a lot of speed with ice due to ice accumulation on all the surfaces that aren't booted like the vertical tails and struts. The engines run hot too due to the ice accumulations around the cooling air inlets. All in all, a bad deal. The boots loose effectiveness the higher you climb too, and really didn't shed ice well in the mid to high teens. I went through three winters in the Pacific Northwest in a booted P Skymaster with full deice, wouldn't do that again. No Skymaster is approved for flight in known icing, and from my experience, for good reason. If you are seriously considering flying in icing, I would look for a plane with much better climb capability that has been tested and approved for flight in icing conditions.
