Unread 03-05-12, 04:36 PM
Just open up the nose gear actuator return line, and the reservoir will drain out. Caution: make sure you have a jack supporting the nose incase the nose gear actuator's mechanical lock fails.
As for the fluid in the rest of the lines you'll have to run the gear to purge it out.
