Unread 03-15-09, 05:25 PM
I usually find the problem is the connection in the wing root, the pins are usually corroded or loose. I'll replace them or clean them then try to close the female pins a little. I have also found the probe wiring inside the tank worn through from years of sloshing around and rubbing on the tank floor.
Hope this helps
Kim
