Unread 02-25-06, 10:34 AM
Roger
The gear motor cuts out on pressure not on gear position.
If the gear motor continues to run although the doors are not closed means one of two things.
1. The pressure switch is intermittant
2. The HYD power pack is not able to build up to the 1500 psi to cut off.
I assume that you have a amber up light on even though the doors are not closed.
If you do that means the uplock switches are ok and the door control valve is not operating or the door lock valve is sticky.
Make sure all the downlock switches are in good condition and work freely and do not leak across the COM to the NO contacts.
Lots of things to have a look at but these would stop the doors from closing
Let me know how you get on
Regards
Pete
