Unread 02-20-06, 11:23 PM
Green light goes out after landing
My gear down and locked green light goes out after I touch down. Anyone ever had this problem?
The kick in the pants is, the light will only turn green again if I manually pump the gear doors open while on the ground -- or cycle gear in the air.
I thought it might be the downlock switch, but the mains check good...still need to look at the nose gear. However, that doesn't explain why it would "reset" after pumping the doors open on the ground -- either the gear down switch is engaged or it's not?
Anyone?
