Unread 09-11-04, 09:23 PM
TAS (Thin Air Seeker)
fuel pump
From your description, the engine is going lean. TIT rising while fuel flow drops. Sound like it can be your engine driven fuel pump. Since it is not a constant problem perhaps on certain flight conditions the engine driven fuel pump gets hot and excess bypass occurs. Frankly, under the condition you have, I would have it check out asap and not fly it until problem is solved. Big problems start small.
Good luck
Jerry
