Unread 09-05-24, 05:40 PM
Scudrunner's Avatar
Scudrunner Scudrunner is offline
Scudrunner is on a distinguished road
Chatting with my mechanic it still seems like a good fit for getting some glass upfront. The last few times plunging out over the Pacific to break through a marine layer didn't sit well with me. That being said it worked fine and did the job. Having some modern glass and a "backup" Vacuum would be great.
This is the response to some questions I asked UAvionix.
"your tailBeaconX will need to be paired with the AV-30C in order for it to work as the AV-30 is the transponder control head."
So I'm outta luck with using the CNX80 as the Transponder control head. doh I figured but might as well clarify it.
Asking about timeline if the AV-APA would be certified and compatibility with the Navomatic 300.
"Right now the experimental AV-APA works with the S-TEC autopilots, however once it becomes certified it will work with the S-TEC, Aerocruise and trio pro pilot anything other than those is uncertain at this point in time."
So sounds like its in the works to be certified but probably not for the Navomatic.
