Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Kim, I appreciate your taking the time to consider this situation and for all that you
contribute to this forum. A well reasoned argument is never snarky and would never be taken as such. We are both trying to achieve the same ends; to realize a shock mount installation that is in conformance with its design intentions and is performing optimally. However, please indulge my continued skepticism the reasons for which I shall endeavor to set forth as follows: Firstly, yes, if the mount halves were to make contact with one another grossly in advance of contacting the engine mount spacer it is conceivable that the assembly could fail to achieve unity however these parts are designed and manufactured to close tolerances. The outside diameter of the mount flanges are just a sliding fit within the inside diameter of the engine mount spacer. When the assembly is drawn together using a 7/16” diameter fastener tightened to 40 lb-ft of torque a tremendous clamping force is achieved unifying the component parts in tension along their mating surfaces. They’re not going anywhere. Secondly, I have attached hereto Lord Engineering drawing no. S-6493 detailing the design installation configuration for the J-9613-31 mounting kit and its component parts. I would draw your attention to the cross-sectional view in the upper right hand corner which depicts a single mating line through the forward and reverse C’s of the metallic shoulder and flange of the mount halves. There is no double line indicating the intention of a gap of 0.15” or of any similar magnitude. Also, please note the dimension of 0.62” across the mouth of the C's. In other words a dimension of 0.31” as being the flange height of each mount half. These values can be confirmed by measurement of the actual part. In short, this manufacturers technical drawing conclusively depicts the installed shock mount halves are intended to mate upon assembly. Thirdly, with respect to achieving the proper preload compression using an AN7 bolt, this is the issue which started this whole critical investigation. The internal length of the mated, uncompressed mount halves minus the length of the internal spacer is 0.41”. This dimension could be called the compression distance. When the mount halves are separated by 0.15” this compression distance increases to 0.56”. The length of threads on this bolt is somewhat variable depending a manufacturer but is generally between 0.5” and 0.6”. On the new hardware purchased for this installation the thread length measured approximately 0.5”. Subtracting 0.1” to allow the nut to be started on the first full turn of thread leaves 0.4” to 0.5” of thread available to do useful work. This is marginally sufficient to accomplish 0.41” of compression distance in the mated configuration but is wholly inadequate to realize the 0.56” of compression distance which would be required to achieve capturing the internal spacer in the gap configuration. And, if one had a fastener of sufficient thread length to realize the mating of the upper and lower mount halves with the internal spacer, the resulting compression of the mount would be some 37% greater than the design intention. This significantly stiffens the assembly ( degrades its elasticity ) and compromises its ability to capture and isolate vibration passing into it. I find the forgoing compelling evidence to conclude that these mounts, as employed in this application, fail to conform to their approved design criteria and are performing less than optimally. If you have access to data which allows for a reasonable alternative conclusion I would be most interested in considering same. Sometimes the “facts” that we are most sure of are the same “facts” that contain the greatest error. |
Thread Tools | |
Display Modes | Rate This Thread |
