Unread 05-18-02, 02:21 PM
GMAs GMAs is offline
George M. Amthor, Jr.
Unhappy
Here is where you can find your answers... and it shows examples... it should be put in the sidebar so that you can see 43-13... but, rather you should obtain a copy so that you can ...refer to the book thing... smile...
http://av-info.faa.gov/dst/43-13/
From here go down to cables and fittings... and you can bring up some pretty good pictures... this is exactly what we went thru down in the meeting... disreguard the plastic coated cables... as we don't use them on the skymasters...
AS to lube... any is better than none.... so even if its LPS 1 or parktone its still better than none... make sure you check the cables by using a rag over them... as your hand will get real bloody if you use your pinkies and you find a broken stran... smile...
