Unread 04-30-22, 08:14 AM
N337RT N337RT is offline
N337RT is on a distinguished road
Easy out should be the last resort. I usually have 99% luck using my river gun and this: (mine is home made, but you can order or make something similar)
Shake N Break Air Impact Screw Remover https://www.amazon.com/dp/B000BHJ7JM...M3EWGJ2KNCF0FB
The problem with this is you need to know how to do it. If you have too much pressure or go too hard you will damage something. I use my rivet gun, which has a very nice variable trigger but same results can be had with lowering air pressure.
