Unread 07-18-21, 05:03 PM
BILLS, I support your decision 110%! The expense is unfortunate, but now at least you should know exactly what you have.
Please let us know what is found.
And I think the rear engine leaks oil on half the 337's out there...the repair is to replace the leaking pushrod tube gaskets, which are held in place only by spring pressure from the pushrod tube against the case. Not a hard job, but you do have to remove the valve cover, rocker arm, and push rod. If you do more than one, make CERTAIN everything goes back exactly where it was!
