Unread 02-02-21, 11:01 AM
I'm in the process of doing that myself right now.
I bought new insulation and vinal for the ceiling panels from AirTex - 215-295-4115. The insulation is fiberglass which is foil backed on both sides.
Additionally, (and I would recommend you check this out also) you can contact Tanya Morris at Skandia, Inc - 815-985-7072 to see what Skandia has to offer. I expect they might have several options for you. I bought new foam for the ceiling panels through her, and she was great to work with. Skandia does have a $250 minimum order you might have to work with.
As a side note, the insulation in my plane had, at some point in the past, been glued on. My IA suggested it not be glued on so inspections can be accomplished.
Rick
N337K-FT337GP
KLOU
