Unread 01-07-21, 11:17 PM
Dr.Dan's Avatar
Dr.Dan Dr.Dan is offline
Originally Posted by frank.oconnor19 View Post
I have a P337 with IFCS 400. I went with a G500txi PFD and G5 as backup. Have a GAD29e and GMU out in the wing. I keep the Vacuum System only because it runs the boots for de-ice. The system is fully couple to the A/P will fly with GPSS and will fly approach through GS capture.
I had Carpenter Avionics do an overhaul on the AP last summer. It works great!. If you need I have the manual for the adjustments on the IFSC 400, full service Manual. There are quite a few things you can manage on your own with intercept angles, scalloping on altitude and turn rates. All meant to be done in the air. I looked at a new AP, but 25K to give me the same functions I have already, albeit more accurate, but seems a bit out of line.
That's good to know, thanks.
Did you have to keep your old attitude gyro for the AP? My understanding is that the g500 or g5 can control the AP, but the original gyro attitude indicator must still be connected for it to work properly.
1973 T337G
