Unread 11-15-16, 02:26 PM
DrDave DrDave is offline
Leighton:
When you get down into the inside of the belly with a pressure washer you can uncover years of grunge that has been coated in hydraulic fluid. You can make the inside look brand new. You will also find enough loose nuts, screws, clamps, etc. to start a small hardware store. There are a number of unpleasant smells lingering in the belly of the plane. All of those will be washed away.
It is so much nicer to work on a plane that is clean and goop free. When I figure out how to post a picture that is not turned 90 degrees I'll send more.
