Unread 10-04-13, 11:08 PM
cawelsh cawelsh is offline
cawelsh is an unknown quantity at this point
1973 P337 Governor Sync issue
I have two matching governors without the little gears. Syncro is via the black box and a parallel driveshaft that lengthens and shortens the rear prop cable a small amount. Trying to find out if the cable, Part # 1550017-8, includes the little piece at the end that is on the prop cable/governor joint that lengthens and shortens? I can't find a separate part number. The little extension bit is internally frozen.
I could use a broken 1550017-8 cable to make a tool to free it up if anyone has one.
Thanks!
