Unread 03-05-12, 08:45 AM
cessnadriver's Avatar
Thumbs down servicing the hydraulics fluids
Hello ALL.
Here's my next Skymaster question. This is mostly for the C337 mechanics but owner's can chime in. My old '65 c337 needs the hyd. fluid replaced, and yes I did check the maintenance manual. The manual is some-what vague. Short of using a Hyd. mule (Hyd test set), Is there a way to drain ALL of the hydraulic fluid out of the system and then replenish it? I want to remove the old fluid because it's probably been in there since the aircraft was new. The fluid is yellow instead of bright red. If possible I'd like to do this WITHOUT CYCLING of the gear. At the present time I have no wings or tail booms installed!
Thanks as always,
BILLS bstory@pa.rr.com
