Thread Tools |
Rating:
Display Modes |
#23
The cost estimates were arrived at by separate parties working independently. I believe they are accurate for the SIDs now under consideration and driven principally by the need to remove and inspect the wing attach bolts. Currently, such removal can be done safely only by separating not only the wings from the fuselage, but also the booms and tail, and derigging the aircraft. Cost won’t be significantly less unless the SIDs are changed or someone comes up with an alternate form of inspection such as X-ray.*
But Rick, if you are a U.S. Part 91 operator, I don’t believe you will be required to perform the SIDs. I have been reading various comments on this Board about the possibility of an IA requiring the SIDs, either out of an abundance of caution or if Cessna issues a revised Service Manual with SIDs. While I can’t rule out a poorly informed IA taken such a stance, I think the record is clear that Part 91 operators will not have to do the SIDs. My basis is the FAA’s Final Rule and Notices (“FRN”) on the matter, which is essentially the mandate for the SIDs. Later I will provide you a link so you may peruse the document, but here’s a summary. The genesys of SIDs was the 1988 in-flight failure of a high-time Aloha Airlines Boeing 737, where a section of the upper fuselage ripped away because of fatigue. Congress pushed the FAA into evaluating steps that should be taken to prevent such future failures in high-time (or “aging”) aircraft. Initially only transport aircraft were considered but that was later expanded to cover smaller aircraft. Both the heading and the first paragraph of the FRN make it clear that only Part 121, Part 129 and Part 135 operations are covered**. Moreover, on Page 5 (3rd full paragraph of the 3rd column) Part 135 cargo-only and on-demand operations are excluded. Concerns that SIDs may become ADs also appear unfounded. On Page 2 (1st full paragraph of the 3rd column) the FAA explicitly states that ADs will be issued only to address “unsafe conditions that have already been identified.” And the Cessna 400-series SIDs supports this, because only one of the SIDs became an AD after cracks were found and a fatal in-flight failure occurred. Given that SIDs were mandated by the FAA and the FRN’s clear intention to exclude Part 91 and some Part 135 operations, I do not believe Cessna can take actions that would essentially contravene the FAA. All of this is small consolation to many non-commercial foreign operators who will be subject to the SIDs. The FRN may be found at http://edocket.access.gpo.gov/2002/pdf/02-30111.pdf. Ernie __________________ * I did some of the initial SID work for SOAPA and coordinated extensively with Don Nieser and others outside SOAPA regarding the effect of the SIDs. I have a Master’s degree in Mechanical Engineering from Caltech, 30 years of experience in aerospace and aviation, and have owned 2 Skymasters over the past 10 years. ** Although not pertinent to Skymasters, SIDs apply only to multiengine Part 129 and 135 operations, so single-engine airplanes are not subject to SIDs unless in Part 121 operations. I mention this because I have seen some arguments that the Skymaster SIDs are precursors to Cessna trying to extend them to its single-engine models. |
| Thread Tools | |
