Unread 02-06-05, 09:25 PM
Frank Benvin's Avatar
front cowl flap motor
Wanted front cowl flap motor for 1967 337B Serial # 650
If you have one you can email my dad
Benny sbbenvin@telus.net
Frank
Unread 02-06-05, 11:04 PM
I assume you read the thread entitled "Need O/H Cowl Flap Moter(Front)", last message 2/3/05, where several people have found that having your mechanic service the unit (mostly cleaning it) often solves the problem.
Unread 02-06-05, 11:50 PM
Thanks Ernie
The 337 he bought is missing the motor.
Frank
Unread 02-07-05, 10:39 PM
Well.... That one will be pretty hard to repair! You might want to check with Don Nieser. He is listed several times on this site. Generally under the parts threads.
Unread 02-08-05, 01:15 PM
If you go to the other thread on this subject, per my first message, you will find three sources: Don Nieser, Owen Bell and Bill Hamerstadt.
Unread 02-08-05, 05:18 PM
TAS (Thin Air Seeker)
cowl flap motor
I suggest you investigate converting the fron cowl flap operation the a n STC cable unit. Owen Bell can do it.
BTW, A friend has a well equipped 414 with Ram coversion. The cowl flaps out on the wing are all non electrical cable operated. Every wonder why Cessna Engineers decided to keep the motor design on the Skymaster?
Jerry
