Unread 03-14-04, 08:42 PM
GJ Humphrey GJ Humphrey is offline
GJ Humphrey is an unknown quantity at this point
Replacements for fuel quantity, cyllinder head temp, oil pressure and temp gauges
Are there any modern alternatives to the 1940s automobile-style rectangular cluster housing the fuel quantity, cyllinder head temp, and oil pressure and temp gauges?
Thanks.
Looking forward to meeting 337 owners at Sun 'n Fun and the OKC 337 Fly-in!
Best,
GJ Humphrey
Unread 03-15-04, 06:16 AM
Interesting you should ask
Go to the home page of this website, select the Technical Data Page from the menu (down the left hand side) and go to the bottom of the Technical Data page. You will see an installation for replacement of all these gages on a 337B. I'm sure Mitchell instruments would be willing to work with you to arrange a similiar mof for your aircraft. You will need to get a field approval before installing it.
I think the current count of these modifications is up to about 20 right now. I know of at least two more from users of this board. You will probably meet them at OKC. You may even be able to see an installation.
We will be at OKC too, but, alas, the Skymaster will remain in Richmond. The airlines beat the flying cost significantly.
Unread 03-15-04, 03:45 PM
Fuel quantity, cyl head temp, oil temp and pressure gauge replacement
Thanks, Jenny.
Does anyone have a photo of a C337 panel retrofitted with the Mitchell instruments as replacements for the original C337 rectangular cluster of fuel quantity, cyllinder head temp and oil pressure and oil temp gauges?
Thanks.
GJ Humphrey
Unread 03-15-04, 04:37 PM
The document that Jim pointed you toward has a photograph in it.
Unread 03-16-04, 04:24 AM
GJ,
Here are some other thoughts on replacing those gages - although these are "approved", I'm not sure the 337 in necessarily included.
The JPI 711 can replace the factory CHT, TIT and Oil Temp. This info is hard to locate on their website - but you can find it in “Downloads” in the 700/711/800 manual pdf. www.jpinstruments.com
Electronics International (www.buy-ei.com) has a number of primary instrument replacements. RPM, MAP, CHT, EGT, Oil Press & Temp, Volt/Amps, TIT
Shadin's Digiflo can be used to replace the stock fuel flow gage.
www.shadin.com/ff_digiflo.htm
Unread 05-07-04, 07:33 AM
N456TL
CPA has recently suggested looking at www.aerospacelogic.com as a source for replacement guages in the latest news letters. They look great.
Unread 05-08-04, 10:52 PM
Jack Moore Jack Moore is offline
Member
Jack Moore is an unknown quantity at this point
replacement?
Does anyone know if the EDM760 is a direct replacement?
