Old 11-17-03, 08:36 PM
Gear
HOPE THIS ISNT A REPEAT HAVE A 1967 02B GEARS WORK FINE DOORS STAY CLOSED TIGHT WHILE ON JACKS WHEN POWER IS REMOVER FROME AIRCRAFT DOORS WILL SAG PLEASE HELP...JACK ....OBX338@AOL.COM
Old 11-17-03, 09:04 PM
How quickly do they sag? hours or minutes, or seconds?
Old 11-17-03, 09:10 PM
THEY SAG A SOON AS BATTERY POWER IS REMOVED ...SECONDS
Old 11-17-03, 11:13 PM
Richard Richard is offline
Do you have the older mechanical hydraulic unit?
Old 11-18-03, 01:13 AM
'67 airplane would be the engine driven hydraulic pump. If you had answered that it took a while, like many minutes or hours, I would have suggested an internal leak in an actuator. But if they start to sag when the power comes off, that sounds to me like a sequencing valve is in the wrong position, and I am not smart enough about the gear system to suggest where. It would be similar to the part of the system that makes the gear doors pump open when the master is off, and closed when the master is on.
I hope one of the smarter folks on the site can offer you more help.
Old 11-18-03, 06:00 PM
FRED-E's Avatar
FRED-E FRED-E is offline
Sagging Gear Doors
Is it the Strut doors (long doors) or the Gear doors (large doors) that are sagging or BOTH?
Fred
