Unread 04-18-02, 02:44 PM
Dale Campbell's Avatar
Gear problem again on 337H
I flew 200 miles from home base & gear came down, did not detent, doors stayed open, power pack kept running until gear circuit breaker popped & I got no green light. I looked in mirrors on wings & gear looked ok. So I put gear up, all went up ok & doors closed. I cycled gear down 5 more times with same problem. I put gear up & tried lowering gear with the hand pump.
still no light. I know the bulb in green light was ok because I tested it on the first time I put gear down. I called the mechanic on the ground & he ran to runway with portable radio & I did a low fly by. He said gear looked ok but all doors are open. So I came around again. When I turn base I put down all flaps. got speed to 90 knots & turned final. When I turned final I heard that familiar clunk when gear detents. Green light came on & I landed.
Doors did not close because I pulled circiut breaker so power pack would not burn up. When on ground I pushed breaker in & doors closed. We put plane on jacks & everything worked good & we could not find anything wrong. So I flew back home with gear down. I have a appointment with O & N Aviation next week. They did annual 3 weeks ago. This is the problem I had all last summer.
I forgot to mention it was over 90 degrees F yesterday when I had problem.
Unread 04-18-02, 04:49 PM
Burt Benson Burt Benson is offline
Burt Benson is an unknown quantity at this point
Dale,
Your problem is misadjusted downlock micro switches. Check those and you will be alright.
Burt
