Old 03-23-03, 10:28 PM
amichelin amichelin is offline
amichelin is an unknown quantity at this point
fuel management system
Hi
I am adding a fuel management system to my 1973 T337GP any suggestions?
Adam
Old 03-24-03, 09:09 AM
Thumbs up re fuel
shadin does a good job. There are more to chose from now including integrated units with engine monitors.
depends on your requirements. Shadin has been the defacto standard.
Old 03-24-03, 09:12 AM
Also,an advantage of Shadin is that it is STC'd as a direct replacement for your analog fuel flow indicator, which saves panel space. I am not aware of any other unit that has similar approval.
Old 03-24-03, 06:15 PM
Talking Shadin
I have the Shadin but also kept my orginal fuel gauges installedas a backup. I am happy with the Shadin and, the people are good to work with.
Jerry
N34EC
Old 03-24-03, 08:06 PM
any particular models mini, micr or?
Old 03-24-03, 08:34 PM
I think the STC's ones are Digiflow and Digiflow-L (which will connect with GPS to get distance remaining on your flight plan, if you have a GPS and use it with a flight plan frequently).
Old 03-24-03, 09:16 PM
re fuel flow monitors
Adam
It really depends if you are intending to do a makeover on your aircraft and installing other instruments. The JPI can integrate the function and I believe EI has one out as well.
Basically the fuel sensor puts out a pulse on a fractional gpm rate. A counter converts the pulses to fuel qty. It is rather a simple instrument. The Shadin can replace the fuel flow indicator on your AC (STC) whereas it is the only one that is certified to do so.
I have it connected to the GPS but you do not need to be an eistein to mentally figure the balance of fuel or remaining flight time to distination. The only thing it does is tell me the MPG and I joke that it is better than a Hummer or a Lincoln SUV <G>. BTW I have had it reading 10.5 mpg.
I wouldn't fly without it unless you are willing to "top the tanks" on every flight.
Make sure you install the orange fireshield over the sensors! Also make sure the fuel lines are removed going to the instrument and have them capped at the fuel controller. I never did like the idea of having the fuel lines (very small) terminating on the back of the instrument panel.
Old 03-24-03, 11:05 PM
Smile
N79C
thank you very helpful
