Thread Tools |
Rating:
Display Modes |
corrosion protection
Anyone recommend spraying equipment for LPS3 ? Anyone have any experience with switching from corrosionx to ACS50 or LPS3?
LPS3 seems to be better and far less expensive than CX. Comments would be appreciated. bob |
Stick to Corrosion X or ACF 50 they will seep into joints and seam where as LPS 3 is thick and waxy and will seal moisture in as well as out.
Kim |
re cpc
Kim
LPS3 is mil spec and has the Boing approval and tests for "wicking". There is some good research paper on CPC @ http://www.virginia.edu/cese/researc...t%20AA2002.pdf .....from the university of Virginia. Great paper....... I was able to obtain the BOING AC wicking test proceedures which this material meets. From what I can ascertain the lps3 is 1/2 the price and far superior to other products based on the fact it will not run off the material and it is "self healing". Wicking does not seem to be a problem. I did corrosion X in the past but I have found some corrosion occuring in places that is shouldn't after being "protected". I can send the boing proceedures and tests if anyone is interested. I am trying to find a product that is better than corrosionx. It does have lubrication properties for cables etc. It is recommended for use on cables and chains. Anyone with other experiences ? suggestions ? ideas ? comments? Bob |
i have been using acf for several years, it seems to work. have no corrosion as of yet (4yr parked on the beach) i do it every year. i usaly do it myself and really soak the hell out of it. the only drawback is the continual seeping or leaking out, usally last until the next application
acf/lps
i have an acf spray pot with attachments. my mechanic laughed and said use the lps and his crude spray pot and lps. comparing the results between the two systems i now leave mine in storage. J
re corrision
Found a great sprayer to do the aircraft anti corrosion spraying for about 30 dollars. It does a great job atomizing LPS3 or any other liquid for that matter.
highly recommended. http://www.jcwhitney.com/product.jhtml?CATID=4503 Fyi Bob |
