Old 09-24-22, 04:47 AM
mikezen mikezen is offline
mikezen is on a distinguished road
Very unpleasant experience !
Hi,
During one of the hottest days in august, just after shut down, I got stuck for almost 2h in my pressurized FT337G (build in France by Reims Aviation in 1974), because the upper clam shell door's front security lock cable broke when I pulled it !
To who it could happen, I recommend having a cruciform screw-driver (with T shape hand grip if possible) to remove the leather trim and a flat plier to unscrew the bottom part of the sleeve in which the cable slides, and finally to pull the cable (some nice people passed me those tools through the window !).
Isn't there a way to unlock the upper clam shell door from outside the aircraft ?
Old 09-24-22, 12:53 PM
That's a scary story for a P-model owner in Texas!
It would be great if you could add some pictures to explain exactly what you had to do!
Old 09-24-22, 09:36 PM
ljmolina's Avatar
ljmolina ljmolina is offline
Yeah, your the 2nd story I heard this happening to. Pictures would be great on what happened and how you managed to get out....since I own a Pressurized G model aswell.
Old 09-24-22, 09:59 PM
I’m an E model and there is an emergency pop out window on pilot side. I know hull design changes with G model and shared with pressurized models. So there’s no emergency pop out for those models?
Old 09-25-22, 05:09 AM
OK !
I'll send a procedure with pictures as soon as possible !
Old 09-25-22, 05:15 AM
Yes : no emergency door on the pressurized Skymasters.
If I'm right, I think Cessna just didn't want to certify a second door and that's why FAA required the POB reduction from 6 to 5.
Old 10-02-22, 11:56 AM
Stuck in your pressurized Skymaster ? This is how to get out !
Hi,
As promised, this is a procedure to get out a pressurized Skymaster in one of the 2 security lock pull tabs break, as it happened to me !
Some more pictures in next tread reply.
Hope it helps !
Old 10-02-22, 11:58 AM
Some more pictures
Here are some more pictures !
Old 10-02-22, 12:00 PM
THANK YOU SIR! Vive la France!
Out of curiosity, how many hours are on the airframe?
Old 10-03-22, 05:05 PM
I think this highlights the need for an onboard crash-ax.
