  #31
Old 12-24-20, 11:45 AM
Dan, what is the price of your kit?
Old 12-24-20, 01:49 PM
300.00
Dan
Old 12-25-20, 10:19 AM
Dan, I really appreciate your work on this project.
Old 12-25-20, 10:31 AM
Originally Posted by Dan schultz View Post
I have ran the heater for 3.5 hours continuously last week in the hangar without any problems. I will have 3 units that should be able to ship by the end of the month. The unit in the circuit with the thermostat pulls 2.3 amps.
As a note, you did well with the amp draw! For those of you without the Maintenance Manual, I have the '74 through '80; my '77 G is 4.3 amps! '74 through '76 is 2.2 (close enough), the '78 is 2.9, and the '79 & '80 is back to 2.2. Well done, Dan!
Old 12-28-20, 02:17 PM
Thermostat for Pitot Heat
For those interested, I also will have new thermostat's available. 39 plus shipping.
Dan
File Type: jpeg 717FEB49-67EE-46CC-BA82-0F83CDCFF9ED.jpeg (164.7 KB, 2482 views)
Old 05-01-22, 07:23 PM
Hi Dan,
I own a 1973 C337G Sky Master, N1873M s/n 33701473. My pitot heat recently has ceased to function. Do you still sell your pitot heat kit as well as the thermostat/heat sensor? If so, what is your current price for all and how do I order? I also sent you an email at the address you posted.
I will see my IA mechanic tomorrow to discuss installing your kit if you have availability.
Sincerely,
Ed Asmus
Sugar Grove, IL
Old 05-01-22, 07:58 PM
Hi Ed, yes for the prices listed.
Dan
N67S
937-603-2459
Old 05-01-22, 08:03 PM
Thank you Dan. I'll be in touch tomorrow after discussing with my IA.
Thank you,
Ed
Old 05-02-22, 10:11 AM
Dr.Dan's Avatar
Dr.Dan Dr.Dan is offline
For those interested, this kit works very well. Get the thermostat at the same time.
dd
1973 T337G
Old 05-07-22, 01:37 PM
PH502 24 volt heated pitot (used ebay)
I know I had mine replaced years ago, and it was under $300 new.
My my, how time flies....
Just curious: Would these work on older 337's, albeit used?
Old 05-07-22, 03:50 PM
The flexible heater is universal for pressurized and no pressurized aircraft. Two different sets of holes.
Dan
Old 05-07-22, 04:20 PM
Pitot heater test
Updating databases, a mech left the pitot heat on, w pitot cover.
Roasted the cover nicely.
Confirmed functioning …for now.
So is the problem the stainless pitot housing, or some thermostat in between?
Old 05-07-22, 08:57 PM
The kit is for the pitot inside the left strut cover, not for the regular style pitot.
Dan
Old 05-08-22, 08:34 PM
YankeeClipper's Avatar
I'm still a bit green about some of these things; does this mean it isn't the right kit for my (seemingly) stock, N/A '69 D?
Old 05-12-22, 09:27 AM
I received my kit from Dan. All is as advertised and well organized. My shop liked what they saw. The kit will now sit on my shelf until August when my airplane goes in for it's annual inspection. It will be installed then and I will report back then on our anticipated success.
Thanks again Dan....
