Unread 06-25-20, 11:46 AM
JimC's Avatar
JimC JimC is offline
Replacement heaters
Does anyone know a source of accurate info for replacement heaters? The information I've found out there is a little confusing.
This site: https://janitrol.aero/southwind-aircraft-heaters/
says we're not eligible for the AMOC and if we want to ditch the AD, we have to get a replacement heater. The existing heater can't be upgraded.
This page: https://janitrol.aero/aircraft-heate...n-information/
says we need an I-2500 series, part number 42D79-1(IS)
This page: https://hartzell.aero/pma/cd11050-1/
also lists the part number as 42D79, replaced under PMA (not an STC.)
This page: http://www.aeroinstock.net/wp-conten...tzellcabin.pdf
says that not too long ago (2014) they were selling for $3300.
But Aircraft Spruce (https://www.aircraftspruce.com/pages...heatersnew.php)
says the 42D79-1(IS) is an I-3500 series, and it's selling for $5961. (Click on part number "07-18420" to get the details.)
There's a 42D79 for sale on eBay (https://www.ebay.com/itm/Janitrol-Co...-/123089334133)
but it's the older B2030 model and *is* subject to the AD (https://www.federalregister.gov/docu...s-models-b1500). It's the same part number, but a different model. It can be upgraded to the I-series according to this: https://janitrol.aero/wp-content/upl...er-Upgrade.pdf
Does anyone have any clarity here on the best way to get a heater installed that isn't subject to the AD?
Unread 07-11-20, 08:59 AM
bigcheese
Switched to C&D
I was getting a little nervous flying behind a 40 year old fuel-air bomb in continuous ignition.
Also, it was getting harder and harder to find someone who could do the pressure decay test.
Put in a separate heater hourmeter, to extend the inspection intervals and usable life.
Otherwise they assume 1/2 your flight time is with heater.
Years back I switched to the C&D heater. Lower maintenance, etc.
The install proved to be a bit tricky, and the heater output seems a bit less.
But no more pressure decay tests.
Unread 07-11-20, 12:29 PM
JimC's Avatar
Thanks for the info. Do you remember roughly how many years back and about how much it cost? I have an hourmeter on my heater and it will probably only get 20 hrs/year.
Unread 07-13-20, 05:20 PM
C&D has the non AD heaters and C&D is now owned fully by Hartzell
