Unread 08-05-18, 10:13 AM
YankeeClipper's Avatar
Getting the Lead Out
Has there been any indication about the fate of the Skymaster engines on this front? The latest discussion I see here is 2013.
I'm rather hesitant to make a purchase unless I understand the future of the TCM 360s a bit more.
Unread 08-06-18, 12:16 PM
All the new fuels planned will be acceptable for use in 99% of engines already out there. At least that is what we are suppose to believe. It's a big deal to make an alternative that the FAA will stamp for a certified airplane. It takes a ton of testing and due diligence on the part of the STC holder to make these mods acceptable.
The area that I am concerned with is the cost, there is already an established price out there and it's damn expensive for 100LL. You think this new fuel is going to be cheaper? I am not encouraged to think so, why would it, we are already paying the price. When it comes down to it we have some very expensive trophies in our hangars.
Unread 08-06-18, 03:26 PM
Herb,
I've seen the FAA update that they have selected their two candidates for the next phase (III I think). They were Swift and Shell. But I can't find any more information about compatibility goals, and haven't come across a number like 99%. Is that meant to be without modification?
On price, I guess we'll find out. As usual, the speculation mill has churned out very convincing arguments about that ... on both sides.
The whole topic appears rife with uncertainty and confusion, honestly. I look at the Petersen site, for example, to find applications for their STC for Mogas. Would this satisfy the impending PAFI requirements? Even if so, in Lower CT I'd have to fly 35 minutes out and back to the nearest airport that has it. And when was the last time you saw auto fuel without ethanol? Around here, it's been a while for me.
Unread 08-07-18, 12:57 PM
I am not aware of any modification required. Phillips is also working on new fuel. Swift is available now and a limited location as part of their due diligence for the FAA. It is typically less money than 100LL but this formula that is being distributed now may not be the final replacement blend. Oshkosh had some forums and info about the new fuels but I didn't really pay much attention to it this year.
Unread 08-07-18, 04:20 PM
kilr4d's Avatar
kilr4d kilr4d is offline
I think it's also worth noting that the Cirrus SR20 is powered by the TCM IO-360-ES. Highly unlikely that there would be a fuel change that grounds the SR20 fleet.
Apart from the fuel pump and prop governor it's basically the same engine as our Skymasters....
_________
John K
1977 337G
CNC3
Unread 08-07-18, 08:30 PM
New SR20 has a Lycoming
Unread 08-07-18, 09:44 PM
kilr4d's Avatar
Thumbs up
Yes, but there's 18 years worth of TCM powered SR20's. Almost 1500 aircraft.
_________
John K
1977 337G
CNC3
Unread 08-08-18, 04:11 PM
To aid in the information flow, the FAA presentation at AirVenture 2017:
https://www.faa.gov/about/initiative.../PAFI_2017.pdf
Unread 08-17-18, 10:19 AM
Unleaded woes and confusion
https://www.avweb.com/eletter/archiv...t=email#231381
Scroll down and find the layman's version of the current issues with the unleaded fuel replacement program. Sounds like things got a little sticky at the presentations in Oshkosh. Now the FAA says they are out of money and the original two companies that had been selected have to let more participants into the private party. What a mess.........
Unread 08-18-18, 02:53 PM
bigcheese
Question Am I missing something?
All combustion engines suck in fuel and air, misting the fuel to get the right ratio, light it off with a spark then blow the expanded hot gasses out the exhaust.
Everything else is merely a refinement of that formula.
My son has a highly modified race car. Oversize the turbo. Put a fat 3 in exhaust so it can breathe easier. Some larger injectors, and fuel pump. Reprogram the ECU on a dyno, and all is well. 350 HP out of basically a 120 hp engine.
So it would seem to avoid detonation, one could change the timing on our farm-tractor aircraft engines to accommodate lower octane fuel. While they may not put out exactly the same HP as before, no detonation issues.
Maybe you only get 180HP out of a 210 hp engine?
Maybe you can't go to 30k anymore.
So you de-rate the whole aircraft performance to what the engines CAN put out.
Better than writing off the whole asset.
The experimental guys basically have to do it.
While their engine performance is known,
the capabilities of the aircraft have to be found out empirically
given whatever engine is on it.
So like that, just go the other way.
Yeah, yeah, I know, FAA would never allow that. Blah blah blah..
BUT, subtract the bureaucratic impediments, and the physics seem undeniable.
An aircraft declared experimental is not bound.
What am I missing?
Unread 08-18-18, 04:11 PM
JimC's Avatar
JimC JimC is offline
Originally Posted by n86121 View Post
What am I missing?
You didn't miss anything on the physics side. It's sound logic. It's the FAA that'll getcha (surprise!)
"An aircraft declared experimental is not bound." This is correct, but it is very difficult (bordering on impossible) to convert a certified aircraft to a usable experiential. Yes, you can move it to experimental R&D, but your operating limitations will be extremely restrictive. You can't get to experimental A-B without redesigning and rebuilding 51% of the aircraft. That's where all the homebuilts are.
Unread 08-20-18, 11:55 AM
Wouldn't it be better to hold out until they develop something that maintains current power, safely? I'm not sure I'd be shopping for a plane through this forum any more if I thought there were alternatives that didn't need de-rating.
Also, my reading suggests there are other considerations beyond detonation being addressed, such as erosion of parts that hold up fine in 100LL (not because of the lead itself). Non-linearities in combinations is another, as mentioned in the AVWeb write-up.
Unread 08-20-18, 02:01 PM
bigcheese
Cool Well...
I was at an aeronautics conference in the midwest some years back.
One fellow told how he 87 year old dad wanted to fly his tail dragger to the event, (we are talking open plains), but his medical had lapsed.
The son said, quite correctly, "Dad, what are they going to do to you?"
The only real constraints, other than the laws of physics, are those we follow voluntarily. Like most laws or regulations, they only apply to anyone paying attention.
The issue would be limited availability of insurance.
But then, my gosh, there are places and people who don't carry any...
Yes, the FAA has a path to 'certify' an aircraft 'experimental,' but only for a limited time, subject to renewal.
My own 337 had some ...ah, er, um 'modifications' (for the USGOV), and the paperwork makes interesting reading.
If my choice was to fly a 'something like' 190HP 337,
because there was no path for the FAA to act (willing or otherwise),
or write it off and park the airplane in the trees, ....
Somewhere in ....somewhere, I read somewhere, is a single Russian helicopter that someone stuffed a V8 agricultural engine into it. It actually flies....last I read.
So physics FIRST. Then other considerations come into play.
Unread 08-21-18, 07:58 PM
It's just all politics guys, we know that even the 100LL issues is really not an issue. I agree the new fuel needs to get us from point A to point B but all this bureaucratic cramp that has to be met is just a bunch of paper pushing. I think that the engine manufacturers should be more involved than they are but they probably just want to sell more engines. We are driving 50 year old airplanes with 100 year old engine technology. And 99% of that reason is because the certification process is so expensive and complicated. We have created a mountain out of a mole hill. I ain't going to get any better so enjoy it while we can before we all park our birds in front of our houses as monuments
Unread 08-30-18, 11:08 AM
Swift Fuel hangs up talks with PAFI
https://www.avweb.com/avwebflash/new...-231453-1.html
