Unread 07-11-02, 08:57 PM
Question Door Seal--Repair or Replace
The door seal on my aircraft (73 P337, sn 127) is original, and has some small holes in it. These are not the factory holes, they are small cuts caused by people getting in and out of the aircraft. My mechanic has a special die and repair kit to repair the holes. However, I'm wondering if I should just replace the whole thing...it is almost 30 years old. Does anybody know about how long it takes to replace, and the approximate cost of the replacement part? Is it something I could do myself and get a sign-off?
Mark
Mark Hislop
N37E
Unread 07-12-02, 11:27 AM
GMAs GMAs is offline
George M. Amthor, Jr.
Unhappy Ahhh..... welll.....
mark... the reason your mechanic uses the die and repair kit... is.... because he is trying to save you the time and work... in replaceing it....
I have done one... and don't care to do another... its not that big of a job but, its time consuming to get everything lined up correctly and back in place....
Nope I would say its not something that you could do yourself... unless you want to do it and then pay to have the mechanic do it again... too many little details and problems.... and you goof.. and your out the bucks for the new one... as y ou won't be making that pressure... at alt.... better to take it to a shop and have them do it... then tell who ever is poking holes in it... to quit or else find another plane to fly in... most of the time its the dirt that the door closes on... that does it... so we have found... keeping this area clean is job 1... smile... GMAs
Unread 07-13-02, 06:00 AM
Mark,
I'm in the middle of having my inflatable door seal replaced (parts come from Riley). I don't know the costs yet, but the shop estimated something like 12 to 16 hours. Most of that time is budgeted for removing and cleaning out the old door seal. Due to the replacement parts being the wrong lengths, I'm already way over that time estimate.
Unread 07-13-02, 06:52 AM
Bob Cook Bob Cook is offline
N69S
kevinmcdo
email me
bob
Unread 04-18-15, 04:06 AM
kragby kragby is offline
kragby is on a distinguished road
Source for replacement P door seal
Anyone have a source for replacement p337 door seal?
Unread 04-18-15, 11:54 AM
JamesC JamesC is offline
These guys used to make them for Riley:
http://ultimatedoorseals.com
You have to call them. They send a kit with a new design pump that does not come under the SB.
They do not have the STC so you will have to execute a form 337 and get approval from a FSDO.
The seal is of superior manufacture and design and does a great job of keeping water out of the acft even when deflated.
Unread 04-18-15, 02:18 PM
CaptainRod CaptainRod is offline
CaptainRod is on a distinguished road
Has anyone had any luck contacting these guys (ultimatedoorseals.com)? I've left multiple messages, both phone and email without getting a response. I need to buy one of the coiled rubber hoses that connect to the door.
Rod Teel
Silver Spring, Maryland
Unread 04-18-15, 05:00 PM
Faxing them worked for me - at 805-525-5286
